I was wondering if anyone has done or thought of doing the following:
Create a view for specific group of users that will allow them to see the status of very specific nodes/applications (up or down) - similar to the below:
Allow these users to perform a specific action (reboot the nodes) and don't allow them to view any information regarding these nodes other than the restricted 'Management' view:
At the same time, these users will not be able to navigate anywhere else (all hyperlinks will be disabled or return an error message)
I have copied the 'Node Details - Summary' view, disabled the left navigation, removed all resources but 'Management' but it only works if I select the 'View Limitation' to be for a single network node, not for a group of nodes. When I make that view to be the 'Home Page View' for the new user, I have to define the default network device. By doing that, I can only see the 'Management' of the default device and I cannot navigate to any other of the group nodes.
Any ideas on how to achieve the above?
