This solution worked like a charm! Thanks!
Butch
I'm assuming this refers to the Basic Alerts configured on each polling engine using System Manager?
If you are using the advanced alerts, then you would only need to do this on the "master" polling/web server, since the advanced alerts pull the info directly from the Orion DB.
