Hi all, i have set a warning threshold at 80 and critical at 85. As you can see the oracle/backup is at 95% yet i haven't received an alert.
How can i ammend this
So this is just the template for the values... where is the alert?
HI i thought by adjusting the values here it would create the alert based on the values
What would be the correct way to set this up
So looking at the screen it seems like you are trying to alert on disk volume utilization... true? If so you will want to create an alert on a node where disk volume utilization is ">" than a "certain value" and the volume type is a fixed disk... here is an example of of a trigger condition for one of ours:
and this is not involving a template or a component...
