Hey all,
I just finished working this up and wanted to share.
Objective: Update the Out-of-box Volume Capacity Forecast alert to allow for volume alert muting and known net-snmp size reporting issues.
For Reference: Here's the Out-of-box alert.
SELECT VolumesForecastCapacity.Uri, VolumesForecastCapacity.DisplayName FROM Orion.VolumesForecastCapacity AS VolumesForecastCapacity
LEFT JOIN Orion.Settings s ON s.SettingID = 'ForecastMinDays'
WHERE
VolumesForecastCapacity.InstanceCaption != 'Virtual Memory'
AND VolumesForecastCapacity.InstanceCaption != 'Physical Memory'
AND VolumesForecastCapacity.InstanceCaption != 'Real Memory'
AND VolumesForecastCapacity.InstanceCaption != 'Memory Buffers'
AND VolumesForecastCapacity.InstanceCaption != 'Cached Memory'
AND VolumesForecastCapacity.InstanceCaption != 'Shared Virtual Memory'
AND VolumesForecastCapacity.InstanceCaption != 'Shared Real Memory'
AND VolumesForecastCapacity.InstanceCaption != 'swap space'
AND VolumesForecastCapacity.DaysToCapacityAvg <= 60
AND VolumesForecastCapacity.MetricName = 'Forecast.Metric.PercentDiskUsed'
AND DayDiff(VolumesForecastCapacity.MinDateTime, VolumesForecastCapacity.MaxDateTime) >= ISNULL(s.CurrentValue, 7)
My Version: I had to include two additional joins to pull in volume size data and custom properties. "AlertSuppression_Vol" is our method of alert muting, inspired by adatole in this write-up: TIPS & TRICKS: Stop the madness! Avoiding alerts but continuing to pull statistics. Instead of multiple mute custom properties though, we use one or more character strings in the single suppression field. Next, I wanted to work around the known issue with net-snmp misreporting volume usage over 2 TB. This should prevent any linux volumes (/%) that are over 2 TB in size from triggering this alert.
LEFT JOIN Orion.VolumesCustomProperties p ON p.VolumeID = VolumesForecastCapacity.InstanceID
LEFT JOIN Orion.Volumes v ON v.VolumeID = VolumesForecastCapacity.InstanceID
WHERE
ISNULL(p.AlertSuppression_Vol, '0None') NOT LIKE '%6VF%'
AND ((v.Caption LIKE '/%' AND v.VolumeSize < '2199023255552') OR (v.Caption NOT LIKE '/%'))
AND VolumesForecastCapacity.InstanceCaption != 'Virtual Memory'
Initial results are promising, but I'm open to comments and suggestions!
Thanks!
