In Orion are we able to sort the order of items in a down list?
Unfortunately the list is not sortable. Is there a particular list this is causing problems or just all drop downs in general?
Drop down sort order is typically alphabetical, though there are rare occasions where that is not the case.
Some of my custom lists, I would like to move the most used to the top or set the most common as the default.
For the above example I would like to make Server the first list item, so it would be the default.
fcpsolaradmin
I find the need for this as well. Currently, for the custom properties that I have created as "Required", I have to create a new value of "A" so it shows up first. Otherwise, if I do not, and the user does not change it (I know, everyone always pays attention, so how could that happen), it will default to having a value of "A", instead of being lost into a different value. I would like to be able to make a "Choose A Value" value, or something similar, and set it as default.
It would also be helpful, at least to me, to be able to have these custom property drop down lists that were only seen for devices/device types that they pertain to. We have numerous different drop downs to choose from, but only a small fraction actually have anything to do with the majority of our devices. Would be nice to be able to create groups of custom properties/drop down boxes, and then be able to assign them to device types.
-Will
