I am trying to apply "AppInSight for IIS" template to my Orion server. but getting below errors.
Please let me know if I am missing something.
Ensure the node is managed via WMI, click "List Resources", select AppInsight for IIS. When you click on AppInsight for IIS from the "All Applications" resource you will be prompted to configure the server, which is configuring WinRM on the remote host. After that you should be good to go. You can even try it yourself on the server where the SAM beta is installed.
Thanks aLTeReGo, issue is resolved. able to poll information for AppInsight for IIS.
How do I see applications running on iis.? I have WinRM,Wmi and powershell are all good.
Are you monitoring the IIS server with AppInsight for IIS?
Yes I am using Appinsight, but some iis components are grey. components like sites, application pools, site bindings, connections and cache.(See attached)
It looks like PowerShell isn't configured, please run configuration as described here SolarWinds Online Help
If the dialog doesn't appear, click on "Edit Application Monitor", enter/choose credentials and run Configuration from this place.
Server Configuration Failed Detailed error information: Connecting to remote server 10.11.203.51 failed with the following error message : WinRM cannot complete the operation. Verify that the specified computer name is valid, that the computer is accessible over the network, and that a firewall exception for the WinRM service is enabled and allows access from this computer. By default, the WinRM firewall exception for public profiles limits access to remote computers within the same local subnet. For more information, see the about_Remote_Troubleshooting Help topic.
Note: PowerShell(With permissions), wmi are all enabled
(See attached snippet regarding PowerShell permissions)
