The "Log Bytes Flushed/sec" component of an AppInsight for SQL monitor is down on some of the databases on 1 of my SQL 2012 instances. The description for that component specifically says, "Note: This is not available in SQL 2012.", so it shouldn't even be looking for those counters on SQL 2012 instances.
So, I have a couple of questions:
- How do I disable that counter component for my SQL 2012 instances?
- I see the counter on all databases on all of my servers, but several of them on my 2012 instances are green. Why does the counter work for these databases and not others?
