Hi!
Has anyone tried setting up a Netpath probe on a voice VLAN and monitor SIP paths? If yes, did it help on troubleshooting any call performance issue?
Any input is much appreciated.
RTP is running in UDP Netpath can work only with TCP..
I will say that the best tool SW has for that is VNQM that support Cisco IPSLA
Thanks for the link on the Feature Request! Knew RTP wasn't really a go because it was UDP, and SIP seems to work with both TCP and UDP so that was my only option. My knowledge in SIP behavior is limited so I was hoping someone has tried it with Netpath and at least got some results.
