HI All,
Good Day !!
We have written a perl script to monitor changes in /boot directory of unix devices , As per the script a back up of /boot in /var/tmp will be diff with the original /boot directory and returns an output
The script runs fine from server level , with the expected output when there is a change in logs as well as when there is no change
But when run from application , during the first polling the script runs as expected and returns a output stating that there is no change in logs ( backup dir is created in /var/tmp )
But when a dummy file is created inside /boot and the script run , it is not returning the desired output i.e: there is a change in logs ( Note : When run from server it is returning an expected output )
