Hello Community,
Can someone please tell me if its possible to have the following table displayed in 'Web Display'
Instead, I can only get the following in web display,
Cheers
Carlton
First, on the poller you showed the screenshot for, choose the vmDisplayName column as your label. Then create a new tabular poller for the remaining mibs that make up the table. Once done, edit the Tabular Poller resource on the website, select all the pollers you've created, then choose as the label, the label for the poller in your initial screenshot. It will then give you the table view you are looking for with each column displaying a different mib in the table.
You'd need to change your label to the vmDisplayName rather than the Guest state. For the other columns in the database, you'd need to create tabular pollers for each column in the table. You could then use the tabular resource and select each poller, then just choose the label of vmDisplayName.
Hi mHarvey,
I'm not entirely sure I know what you mean. However, I will give it a try...
That worked like a dream
Would I need to create one for everything in the table, or just the fields I want to display?
