I want to get the 6500 series environment temp values and put them in graph.Is there any one using this at the moment.
Thanks for your help
If you're using the latest release, this is included in the Health Monitoring, provided the SNMP view configured on your 6500 allows those OIDs to be polled. It will be on a tabbed graph with the Power Supply details on the Node Detail Summary page.
If you want to check, import this poller and test against your 6500: http://thwack.solarwinds.com/docs/DOC-30046
-Andrew
