NPM-12.2
SAM-6.6.0
I am trying to remove the "System Idle Process" process's with a SQL filter under the Edit button from this resource and it takes me to this link.
I see these Processes due to my WMI check, checking on these processes. I want to remove these 'System Idle Process' from this resurce
SolarWinds SQL Filter examples
SQL Filter Syntax Examples
Is there a list of Orion tables or values available to use with these SQL filters? The examples they list aren't that great.
Can you help me with what my filter needs to look like here?
Thanks!!!
