SAM comes with a template to monitor an ASM instance - "Oracle Automatic Storage Management".
Appreciate any feedback on how you are monitoring the availability of ASM instance.
Have you seen this, sqain? Oracle Automatic Storage Management this explains how that template works..
Hi Janene,
Thanks for this link. I did go over this explanation.
ASM does not allow direct connections. I guess this template connects to the underlying database and then issues these SQL statements. In a way, this is indirect monitoring of ASM instance.
I was wondering if there is any way for direct monitoring? Perhaps a shell script that is called by SAM?
Syed
