Hi All,
I would like to ask if it is possible or advisable to install Solarwinds Orion NPM and NTA on virtual machine server like VMware.
The Scenario is that we're going to install Solarwinds Orion NPM and NTA on one virtual machine and then its SQL database server on another virtual machine.
As per Solarwinds recommendation, Solarwinds Orion and its database should be installed on different servers. I'm thinking if it is possible to install Solarwinds and its database server on the scenario that is stated above.
Thanks!
