hi,
I'd like to add the "Nodes with Problems" resource to my Orion NOC screen, but the resource isnt listed. Any ideas?
Stuart
Applications with problems is an APM resource. Look under APM Application Summary Reports - Resources that display overall application status. What you want is called "Applications by Current Status". Rename it to "applications with problems" and set it to show everything that's not in an "up" state.
So when you click, Customize this page, it doesn't show up in the list at all?
On the "Network Summary Home" screen I click "customize this page" then "add resource to column 1" and the "applications with problems" resource is not available.
Apologises - I put "nodes with problems" in the first post. It's "applications with problems" that I'm after.
