Hello,
I didn't found way to create custom page when i can show utilization port from different nodes, like Mrtg or Cacti.
For example:
Does anyone know if this is possible ?
Regars
Rafi Shemesh
Hi Silverbacksays,
Yes this want i am looking for,
I will try and let you know.
Regards
Rafi
Not really sure what you're asking. If you are asking how to see Interface Utilization for an individual interface then you just click on that interface in Orion and you will go to that Interface's "Interface Details" page. From there you can see all the info you need about that interface, including its utilization, speed, bps, etc... If you are saying you would like to display a specific interface's utilization and/or bps on a summary page, then you can put a resource called a Custom Object Resource on any view you want and choose the interface you want to see utilization and/or bps about. Just make sure that you only put Custom Object Resource on summary type views, not details type views.
Hey rafish. Just to elaborate on xtraspecialj's comments above, what you're looking for is a custom view for your important interfaces, yes? And you want to be able to view this independently, without first having to go to a parent node? If I'm right, then these are the steps you need to take:
Hope this helps!
rafish Here are a couple of other links to achieve similar results.
How to create a simple custom view of multiple interfaces' bandwidth utilization
Custom SQL Dynamic Graphing Resource
Thank you,
-Will
Sorry for delay, it was very helpful.
