i had migrate Orion V7 to V8 and it goes ok but when i migrate it to v9 i had the following error: "that software license key is for a different computer/software package combination"
Any Help Please
Hi Mohamed,
You should open a ticket with the customer service to ensure you can correctly license your Orion NPM.
To Open a Ticket: http://www.solarwinds.com/support/ticket
In the form, select Customer Service.
-Yann
Dear Yann;
one more question, i had migrate from orion 7 to orion 8 with the same license and there was no problem in that
the question is after migration from orion v 8.5 to orion 9 shall i deactivate the license for the orion 7 from the license manager?
HTH,
Yann
Thanks for you quick response
So you want to say that i have to uninstall orion version 8 first and then install orion 9?
and if that so , the problem is that iam migrating on the same server?
