Hello,
We have several SQL instances on several different clusters. I cant get APM to see the Virtual IPs or Names of the SQL isntances on the clusters.
Orion sees the nodes fine. But wont connect to any of the hosted resources. DNS is fine, see all the Virtual names and IPs. I can remote to the virtual IPs and Names. I can ping them, and of course SQL is working fine with the Front Ends.
We are currently using Orion Network Performance Monitor 9.5 SP3.
SQL 2005 Instances on Windows 2003 64-bit Clusters
MSheehan77
