FYI, the wildcard character in the SQL filter when editing the top xx component resource is %, not * as the documentation at the help link would lead you to believe.
Resource: Top XX Components by Statistic Data (SAM). Click Edit, in the filter field, enter Monitor.Name Like '*something' as the documentation suggest and you get NOTHING! However, enter Monitor.Name Like '%something' and you get results.
This is were the link sends you: SQL Filter Syntax Examples
Just FYI in case someone comes looking for the same thing I was.
