SW support has been working with me but no solution has been found yet.
Case#: 293935
After upgrading to 10.2, I have been experiencing web page timeouts, followed by the Module engine crashing. Support rep has taken quite a few steps to get things running better. When it's working, the website response is much better now, due to these actions. But then, after 30 minutes, sometime less, sometimes more, the module engine crashes, and I get several errors in the event viewer.
Support rep is leaning towards the problem being related to DB performance, which is a possibility. But the problem I have with that is that everything had been running very smoothly before the upgrade to 10.2.
Server specs.
poller: 2008 r2 2x quad core xeon 2.4 Ghz processors. 16 gigs of ram
DB server: 2008 r2 2x quad core xeon 2.66 Ghz processors. 16 gigs of ram
Unfortunately, the DB is on raid 5 disk, not raid 10. (upgrading is probably not an option. politics
If any other SW support tech could take a look at the case and offer any help, I would be very appreciative.
As of now, our Orion server is on the edge of being useless, and we rely on it heavily for monitoring and reporting.
thanks,
Jeremy
event view errors:
| | | | | [ Name] | SolarWinds.Orion.IpSla.BusinessLayer |
| | | | | [ SystemTime] | 2011-12-14T17:20:23.000000000Z |
| | | Computer | GDLLSDSRVSHC174.ls.gdls.com |
| | | Service was unable to open new database connection when requested. Exception Timeout expired. The timeout period elapsed prior to obtaining a connection from the pool. This may have occurred because all pooled connections were in use and max pool size was reached. Connection string - Data Source=GDLLSDSRVSHC173;Initial Catalog=NetPerfMon;User ID=SolarWindsNPM;Password=*******;Connect Timeout=20;Load Balance Timeout=120;Workstation ID=GDLLSDSRVSHC174 |
Followed by this error:
| | | | | [ Name] | SolarWinds.NPM.BusinessLayer |
| | | | | [ SystemTime] | 2011-12-14T17:28:14.000000000Z |
| | | Unhandled exception: Exception of type 'System.OutOfMemoryException' was thrown. |
