How do i set up an alert that says "if component name x has statistic value > 2 for 3 consecutive polling cycles (or instead use for 15 minutes), then alert?
I'm having trouble understanding this.
Actually I found under the trigger alert section "do not trigger unless conditions met for X seconds/minutes/hours."
I just set that to 16 minutes. That should do it right?
