Can Orion monitor mounted volumes?
What exactly do you want to monitor/watch? On what operating system?
The Operating system is Windows 2008.
We're using exchange with a SAN, and I'd like to monitor the size of the mounted volumes. The path to my mount point is \LUN.
APM doesn't ship any default template to do that. But you can do that by using PowerShell Monitor or Windows Script Monitor and some custom script.
Thanks for the suggestion but unfortunately Windows scripting isn't one of my strengths.
Someone suggested I use the Performance Counter Monitor to search for the mount point and selected % Free Space. This worked for me.
