We plan to install NPM SL250 with APM 50 and NCM DL 100 on the same server.(and i think it would be a virtualized server)
From what i have seen the hardware requirements is about 2ghz and 2GB of memory for each application.
Does that mean that we need a 6Ghz CPU machine with 6 GB of memory ?
Have you some advice about the SQL database for those 3 products installed on the same server what is the best solution :
- install SQL express on the server itself
- use an instance of SQL server installed on another server ?
Another question about the operating system of the server: did you recommend windows 2008 or windows 2003, both are supported but in terms of performance what is the best ?
Cheers
