So I'm trying to figure out if I just have a screwed up Orion 10 SP1 installation (and causing goofiness with my Orion) or I'm doing something wrong. I'm hoping it's the latter.
I am trying to set an alert that will notify me when the percent used HD space changes on a server. So I set up the alert for "Volume" equal to "Fixed Disk". Then I add another simple condition saying to trigger if the "Volume Percent Available" -> "Has Changed". That is it. A very simply query, just the 2 conditions.
The alert is set up to activate in NPM as well as e-mail me a notice of the volume change. If I test the alert, it works: The event manager shows the trigger and I get an e-mail notification.
My next test is copying a very large amount of data from the network to the hard drive. Basically, the HD sits at 9% used and over a period of 30 minutes, it will jump up to 22% used (copying about 40G of data).
Problem is: Nothing triggers. I monitor the volume. I have the polling interval set to 120 seconds, and also set my web console to refresh every 2 minutes. Nothing. The percent used goes up, but I don't see any event triggered.
Now here is the other goofy thing: If I open the Solarwinds Database Manager, select the "Alerts" Table and run a SQL query to show me all of my alerts: The list in the DB doesn't even match the list of alerts I have configured (see screen shots). Is there another table alerts are stored in or something or is my installation screwed up?
