Hi There,
I am new to Solar Winds so i do apologize I get don't terminology correct. I come from a software development background so if again, my apologies.
So my client is using AppInsight for SQL Server and they are deployed on several nodes. Some of the nodes are development nodes and the a lot of the SAM can be disabled from there thus bringing the licensing down to within acceptable limits.
Exact Error im getting in the Events Log in Orion is
Component "Buffer Cache Hit Ratio" for application "MYAPP" on node "Server XXXXX" is not licensed
Component "SQL Server Events" for application "MYAPP" on node "Server XXXXX" is not licensed
Component "Top Expensive Queries" for application "MYAPP" on node "Server XXXXX" is not licensed
Component "SQL Agent Job Info" for application "MYAPP" on node "Server XXXXX" is not licensed
Component "Top Active Sessions with Statistics" for application "MYAPP" on node "Server XXXXX" is not licensed
Component "All Databases" for application "MYAPP" on node "Server XXXXX" is not licensed
Component "Recompilations/Compilation" for application "MYAPP" on node "Server XXXXX" is not licensed
Component "Target - Total Server Memory" for application "MYAPP" on node "Server XXXXX" is not licensed
Can an application template be applied to a node with specific monitors activated or is it just something that once its selected its all turned on and needs to be manually turned off one by one
Thanks.
