Is there something I need to configure in Netflow or NTA?
Hello kange0010
NPM doesn't monitor HSRP out of the box I'm afraid you would need to use a Univeral Poller to grab the OID and then it can monitor the State change for you. Alternatively, you could use syslog and alert on state changes.
Monitor HSRP State Change with Alerting - SolarWinds Worldwide, LLC. Help and Support
Kind regards
David
I'll give this a shot David and see what I can do. Thank you.
