I am trying to apply the AppInsightUser for SQL template to some clustered servers hosting our SQL instances. I followed the instructions provided in the guide, added the virtual IP of the cluster, selected the instances on the node (virtual IP), assigned the port and credential to each instance.
When I added the virtual IP of the cluster it resolved to the name of one of the member servers. The name it populated was not necessarily the server the active instance was on, where does it pull that name from? I have both member servers in SolarWinds, but am only monitoring basic health and status. I do not have any of the instances selected in their resource list.
There are five instances on the cluster, they are not all on the same server, they are dispersed between the two. Each instance has an IP address different than the host. I don't think SolarWinds can tell which server is active because of this. None of the instances will authenticate through the AppInsightUser monitor. Neither the server or the database show any login failures or attempts.
From the SolarWinds server (database manager) we are able to authenticate and connect directly with the IP address of the instance. So we know the credential works with the instance and the network is passing the traffic.
Our theory is that because the virtual IP address is not the same as the instance, the monitor cannot connect with the instance itself. That it is trying to connect to the server. I tried to add the IP address of the instance itself and SolarWinds doesn't know what to do with it because it just wants to connect via WMI.
So can I monitor clustered SQL instances that:
1. Do not have the same IP address of the host server
2. Are not all active on the same member server
3. Is there a way to set up the ApplnsightUser monitor to poll the instance by IP address?
Thank you,
Jan
