Hi All,
Can we customize AppInsight for SQL as per our needs. In our environment we only need few paramters & want to disable others like Buffer Manager ,Memory etc. I dont see that option anywhere
You can disable some of them such as Top Expensive Queries. Edit Application Monitor, expand the component definition and set Enable component to 'Disabled' by using the 'Override Template' button. Unfortunately, you cannot disable Buffer manager, Memory, etc.
If you simply don't wish to be alerted on those components, simply remove the warning and critical threshold values. This is the functional equivalent to disabling components in AppInsight applications.
