Is this Possible?
I tried creating an alert, but only want it to check the volumes on certain nodes.
Nodes are in a Client Group which are under a single group for the desired Hosting Provider.
I wasn't able to find a way to this, so i quickly created a Node Variable 'Hosting_Provider' so i should now be able to run the Alert on the volumes on those nodes.
I also need to use an email address and a code which are dependant on the Client (Two Group Variables and populate for the client groups) Can i use Group Variables when sending emails from alerts on Nodes?
As you can tell, we are just putting the new system together :-)
David
