Is it possible to graph or create a report which shows the number of clients associated to the various SSID's?
Regards
Miron
I believe you should be able to do this in report writer using advanced SQL, maybe one of the SQL gurus here on thwack can help you out
I also have the same requirement to be able to run a report that shows clients by SSID.
We are in the process of migrated to a more secure WPA2/PEAP solution and need to be able to report on clients by SSID to track the progress of the migration and to target systems that need to be updated with the new wireless profile.
This is the only post I have found relating to this query, but I do not see a solution posted.
Has anyone been able to configure a report to accomplish this? If so, would you mind sharing the report or the steps needed to configure the report?
Thank you.
I havent seen anything improve in the inbuilt sw functionality that would allow this. Appears it is not on SW priority list.
Hi Miron:
I've marked this for the PMs to check out since it's an older thread.
Bump. I've also been asked to provide this type of report.
