HiI have a skype application template which monitors the amount of current calls. You can see below the stastic for incoming calls is 7. I have applied this application template to 6 servers.I now want to display this statistic on a view. I want to show the total inbound calls over the 6 servers (totals 40-50 calls) I have managed to achieve this via a custom chart using the sum function (Shown below) The issue I have is the chart uses up to much space. Is it possible to make it look like below. Also I want to add the total amount of outbound calls on the same chart if possible so it looks like below. Does anyone know if this is achievable
