This is the error I am getting while trying to use Network Atlas after 30 seconds. Has anyone else seen this issue?
We reinstalled Network Atlas and also rebooted the server which didnt work.
Also tried the local Orion admin account with no success.
We ended up finding a Interface that was at a polling interval of 0. When clicking on this interface within the UI there was an information service error.
Running this query within DB manager identified the interface and interface ID
SELECT TOP 10 InterfaceID, nodeid, InterfaceName, PollInterval
FROM [dbo].[Interfaces]
where pollinterval =0
After removing the interface via Manage Nodes the Network Atlas started working correctly.
I currently have the same exact issue in our environment. We are running NPM 12.
Log associated with opening Network Atlas. Whenever it shows the "Operation in progress, waiting for a connection..." window there is nothing that is logged. Did this same process on a different NPM 12 server and had the same exact log result with no issue.
Log pulled from C:\ProgramData\SolarWinds\NetworkAtlas
2016-06-22 10:11:56,338 [1] WARN NetworkAtlas - Starting Network Atlas version 1.15.0.287
2016-06-22 10:12:01,635 [6] INFO MapEngine - Map MapEngine started.
2016-06-22 10:12:01,635 [6] INFO MapEngine - using WindowsCredential with username **my username**
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - Custom properties: 16
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: Comments
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: NodeID
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: Brand_Name
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: City
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: Country
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: DecommissionedOn
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: Department
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: DeviceType
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: DocumentLink
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: NetFlowDestination
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: Network
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: Owner
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: Primary_Application
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: Region
2016-06-22 10:12:03,728 [8] INFO NetworkAtlas - property: Site_Code
2016-06-22 10:12:03,760 [8] INFO MapEngine - Reading top level entities
2016-06-22 10:12:03,853 [8] INFO MapEngine - Get Available Maps Execution time: 00:00:00.0985144
2016-06-22 10:12:04,150 [8] INFO MapEngine - Query Top Entities Execution time: 00:00:00.2957487
2016-06-22 10:12:04,150 [8] INFO MapEngine - Fill Top Entities Execution time: 00:00:00.0002676
2016-06-22 10:12:04,150 [8] INFO MapEngine - Evaluate Map Statuses
2016-06-22 10:12:04,291 [8] INFO MapEngine - Done Evaluate Map Statuses. Execution time: 00:00:00.1360192
2016-06-22 10:12:04,291 [8] INFO MapEngine - Starting background read of all entities
2016-06-22 10:12:04,291 [Entity Reader] INFO MapEngine - Starting background read of all entities
2016-06-22 10:12:04,306 [Entity Reader] INFO MapEngine - Background Entity Read Start.
2016-06-22 10:12:04,760 [6] WARN MapEngine - Cannot find icon image on path: Maps\Applicationss\Applications.gif
2016-06-22 10:12:04,775 [6] WARN MapEngine - Cannot find icon image on path: Maps\Applicationss\notfoundicon.gif
2016-06-22 10:12:04,791 [6] WARN MapEngine - Cannot find icon image on path: Maps\EndpointServicess\EndpointServices.gif
2016-06-22 10:12:04,791 [6] WARN MapEngine - Cannot find icon image on path: Maps\EndpointServicess\notfoundicon.gif
2016-06-22 10:12:04,807 [6] WARN MapEngine - Cannot find icon image on path: Maps\Agentss\Agents.gif
2016-06-22 10:12:04,807 [6] WARN MapEngine - Cannot find icon image on path: Maps\Agentss\notfoundicon.gif
2016-06-22 10:12:04,822 [6] WARN MapEngine - Cannot find icon image on path: Maps\StorageArrayss\StorageArrays.gif
2016-06-22 10:12:04,822 [6] WARN MapEngine - Cannot find icon image on path: Maps\StorageArrayss\notfoundicon.gif
2016-06-22 10:12:07,244 [Main Window UI thread] INFO NetworkAtlas - 13 maps are available for selection in welcome dialog.
2016-06-22 10:12:20,744 [Main Window UI thread] INFO NetworkAtlas - 13 maps are available for selection in welcome dialog.
Fancy seeing your here Ben, I'm also getting this issue with a client site running NPM 12
I am getting it as well
.I opened a ticket (support case #1007389,) since we don't seem to have any response in the community as of yet.
In my case I ended up rebooting the server and it started working again afterward. Not sure if I had done something previously that helped but when in doubt, give it a reboot?
That worked perfectly, cheers!
Say what now?
This is happening on a remote server but not on the server itself for me.
