I'm a newbie, but I'm configuring Alerting under 9.5 which we upgraded to recently. We only installed 9.1-SR5 a few days prior to that.
I have configured basic and advanced alerting to alert into the eventlog if a node reboots.
When I run a manual test under Basic Alerts it logs correctly into the event log
When I run a manual test under Advanced Alerts it Fails to write to the eventlog
If I actually reload my test router I'm using in the model office, the reboot shows up under events view in System manager but nothing is logged into the eventlog.
I've rebooted the server, doesn't fix
Have run diagnosics and it says that its written to the eventlog OK.
Have run a repair and this has not fixed. Alerting was not tested under 9.1-SR5 as we upgraded to 9.5 before gettting to this so i can't tell you if it worked under 9.1
Any advice greatly appreciated. We have a old 100 node licenced 7.8.5 version that works fine ironically enough.
Regards
Dan
