Hello Thwackians,
We have a script in linux script component monitoring that gives output in multiple lines for message field.
But looks like Solarwinds supports only single line for the message field.
#!/bin/bash
scfile=/home/bpmrg/stale_count
mount_list=/home/bpmrg/mountlist
mount_check=$(cat /proc/mounts | grep -E 'autofs|nfs' | awk '{print $2}')
echo "$mount_check" > $mount_list
echo > $scfile
for i in `cat $mount_list`
do
stat $i > /dev/null 2>> $scfile
done
stale_count=$(cat $scfile | grep "Stale" | wc -l)
if [ $stale_count -ne 0 ]
then
stale_mount=$(cat $scfile | awk '{print $4}' | sed -e s/\'//g -e s/\`//g -e s/://g )
echo "Statistic.NFS_mounts: $stale_count";
echo -e "Message.NFS_mounts: NFS Stale mount found
$stale_mount";
else
echo -e "Message.NFS_mounts: NFS Stale mount not found
$stale_mount";
fi
rm -rf $scfile
exit 0;
Script Output :
Statistic.NFS_mounts_count: 3
/share
/share1
/mnt
Since this output has multiple lines it shows as NA
Script output in Component monitor :
Message.NFS_mounts:NA
Statistic.NFS_mounts: 3
Need an actual output as per the script :
Statistic.NFS_stale_count: 3
/share
/share1
/mnt
how to get the multiple lines in the message field for linux/unix component monitoring...
Vijay
