I have a WMI node that I setup in Orion with SQL Server running on it; however, it's not showing the AppInsight for SQL as an option under the List Resource section. When I try to force assign AppIngight for SQL in SAM it gives me a timeout when trying to authenticate. The logs on my server indicate that Orion is telling the system that it's using a Direct SQL login but sending Windows Mixed Mode credentials which will never work.
Anybody have any thoughts on this?
