Hi Folks,
I just wanted to share a case I have open with SW support relating to installing FOE on an additional polling engine that has the NCM 7.1.1 additional polling engine components installed. The short story is it does not install. It see's the NCM APE components and thinks it is not a POLLER thus does not allow the license to be applied.
So, if you are going to be upgrading or installing, please be aware of this. The current work around is to remove the NCM APE components until a new version of FOE can be released. ETA is unknown.
Sohail Bhamani
Loop1 Systems
http://www.loop1systems.com
