I am curious if it would be workable to setup a single server Orion installation with both Orion NPM (SL100) and SAM (AL150) running with a SQL Express database?
Thanks in advance for any responses!
Byrona,
We shouldn't stop you from doing that, though, as I am sure you are aware, SQL Express is severely limited:
HTH,
Andrew
Thanks for the response. I was aware of the size limitation of SQL Express. I am curious if it will handle the insallation so long as I don't use crazy polling intervals and data retention?
There are lots of variables, of course, but you should be able to maintain some level of monitoring for a relatively small number of objects.
Please post back here for the curious, myself included...
