Can anyone explain to me what causes this error. I get it when i am in the web interface and try to add or edit a user in the admin section. any help is appreciated.
Site Logo jasond (log out)
Orion Website Error
An error has occurred with the Orion website.
Additional Information
System.Configuration.ConfigurationErrorsException: Could not load file or assembly 'SolarWinds.Web.Gauge.V1, Version=1.0.0.0, Culture=neutral, PublicKeyToken=6078881efdf7945d' or one of its dependencies. The system cannot find the file specified. (C:\InetPub\wwwroot\SolarWinds\orion\voip\web.config line 65) ---> System.IO.FileNotFoundException: Could not load file or assembly 'SolarWinds.Web.Gauge.V1, Version=1.0.0.0, Culture=neutral, PublicKeyToken=6078881efdf7945d' or one of its dependencies. The system cannot find the file specified.
File name: 'SolarWinds.Web.Gauge.V1, Version=1.0.0.0, Culture=neutral, PublicKeyToken=6078881efdf7945d'
at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
at System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.Load(String assemblyString)
at System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
--- End of inner exception stack trace ---
at System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai)
at System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig)
at System.Web.Compilation.WebDirectoryBatchCompiler..ctor(VirtualDirectory vdir)
at System.Web.Compilation.BuildManager.BatchCompileWebDirectoryInternal(VirtualDirectory vdir, Boolean ignoreErrors)
at System.Web.Compilation.BuildManager.BatchCompileWebDirectory(VirtualDirectory vdir, VirtualPath virtualDir, Boolean ignoreErrors)
at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath)
at System.Web.UI.TemplateControl.LoadControl(String virtualPath)
at Orion_Admin_ModuleUserSettings.PropControlPlaceHolder_DataBind(Object sender, EventArgs e)
at System.Web.UI.Control.OnDataBinding(EventArgs e)
at System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding)
at System.Web.UI.Control.DataBind()
at System.Web.UI.Control.DataBindChildren()
at System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem)
at System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource)
at System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e)
at System.Web.UI.WebControls.Repeater.DataBind()
at SolarWinds.Orion.Web.UI.CollapsePanel.DataBind()
at Orion_Admin_ModuleUserSettings.OnInit(EventArgs e)
at System.Web.UI.Control.InitRecursive(Control namingContainer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context)
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.orion_admin_editaccount_aspx.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
SolarWinds Orion Network Performance Monitor 9.0 SP2
1995-2008 All Rights Reserved
