I need to have SolarWinds check at 6PM to see if a computer is turned on, and alert if it is. How do I do this?
You can add computer as ICMP device. In the alert setting you need add Alert time interval depending on pooling interval.
It's in as ICMP now. I just need the alert to check at 6PM and alert if the node is up.
