Script
Command line perl ${SCRIPT} localhost
#!/opt/perl/bin
if (@ARGV[0] =~ /\bhelp\b/)
print "MemoryUsage.pl SNMPver community hostname\n";
print "SNMPver - version of SNMP protocol\n";
print "community - community name of SNMP protocol\n";
print "hostname - hostname which will be probed for memory usage\n";
exit 1;
# Get hostname and trim newline
$localhost = `hostname`;
$localhost =~ s/\s*$//g;
$hostname = shift || $localhost;
$community = shift || "public";
$version = shift || "v1";
$results = "";
$MIB_TotalMemory = "UCD-SNMP-MIB::memTotalReal.0";
#$MIB_TotalMemory = "UCD-SNMP-MIB::memTotalReal.0";
$outres = "snmpget -$version -c $community $hostname $MIB_TotalMemory |";
open(OUTMEM,$outres) || die "Unable read pipe\n";
while ($line = <OUTMEM>) {
if ($line =~ /\bINTEGER\b/) {
$indval = index($line,"=");
$indval = index($line,":",$indval);
$val = substr($line,$indval+1,length($line) - $indval);
$val =~ s/[a-zA-Z\/\n ]//g;
print "Message: Available memory at host \"$hostname\": $val in kB\n";
print "Statistic: $val\n";
exit 0;
print "Statistic: 0\n";
exit 1;
the error message I get is
Testing on node cgappl1: failed with 'Undefined' status
| Script execution failed. Input string was not in a correct format. |
