Hello,
Our DBA's are trying to build some disk capacity planning reports for the databases that we have rather than using there manual methods.
In the report builder within the orion console i have select the resource as "Resource: Disk (SAM Appinsight for SQL)"
Then it asks me what objects i am going to report on, it shows me a list of my AppInsight SQL applications in which it will only let me select one of them to report on, except i want to report on all my SQL DB's
Is there a limitation here? i see it says "Selected resource is designated to work with specific objects only.." i assume this means you can basically only select one instance to report on.........
Does anybody have any work arounds for this, seems rather annoying that it cant do such a simple task.
Apologies for the red scribbles on the screenshot, IT Security and all that.
Regards,
L.
