I'm fairly new to NCM, but I'm hoping someone can answer this weird problem I've come across. I've created a config change template to upload files from a local tftp server to a Cisco switch. It works ok, but if I try and upload ANY file with a filename beginning with the letter t (e.g.test.txt), it fails! Files such as "abc.txt" or "bcde.txt" or an IOS image bin file are fine, but "text.txt", "toolong.txt" or "tuvw.txt" all fail.
When I click on the link to "show commands in new window", the script has dropped the "t" and inserted a space instead.
The script should say "copy tftp://10.1.1.1/test.txt flash:test.txt" , but says "copy tftp://10.1.1.1 est.txt flash:test.txt"
I've read the thwack article about inserting special characters, but it doesn't really help. Please see attached screenshots and the code below.
Any suggestions would be much appreciated,
Mike
.CHANGE_TEMPLATE_DESCRIPTION
This is a base change template to act as a starting point for other templates.
.PLATFORM_DESCRIPTION
Replace with details of the device platform for which the template is being created.
.PARAMETER_LABEL @ContextNode
NCM Node
.PARAMETER_DESCRIPTION @ContextNode
The node the template will operate on. All templates require this by default. The target node is selected during the first part of the wizard so it will not be available for selection when defining values of variables.
.PARAMETER_LABEL @Var_TFTP
Enter TFTP server IP Address
.PARAMETER_DESCRIPTION @Var_TFTP
eg 10.1.1.1
.PARAMETER_LABEL @Var_Sourcefile
Enter source file name to upload
.PARAMETER_DESCRIPTION @Var_Sourcefile
e.g test.txt
.PARAMETER_LABEL @Var_Destination
Enter destination file name on flash
.PARAMETER_DESCRIPTION @Var_Destination
e.g test.txt
script BaseChangeTemplate(
NCM.Nodes @ContextNode,
string @Var_TFTP,
string @Var_Sourcefile,
string @Var_Destination )
//TODO - insert details of change template
string @SlashSymbol=';/'
string @String_CLI=@Var_TFTP + @SlashSymbol + @Var_Sourcefile
//Enter CLI commands
CLI
copy tftp://@String_CLI flash:@Var_Destination
