Is there a way to easily create firmware upgrade jobs as opposed to 'adding' a firmware upgrade job one at a time via the wizard?
Let's say you have 500 remote sites that need a firmware update. I can't necessarily create 1x job with 500x nodes or 5x jobs will 100x nodes.
Creating a job seems to take about 5-10 minutes this makes it a little more time consuming to deal with. I do not want to put too many nodes in a single firmware upgrade job either. In my testing if a node fails, the jobs ends and any subsequent devices in that job do not receive their updates.
I understand that multiple firmware operations may occur at the same but it appears to me that only device in each job is updated at any specific time.
