# I am running SAM on Win 2008 r2 64 bit - running MSSQL Server 2008 and SAM 6.2 - NPM 11.5
# I Did run the AppInsight for SQL template but we do not need all of the monitored SQL item its uses plus it uses too many license's - I just need to know when the SQL Agent JOB Fails
example :
# I did try using this Thwack template but I can not get it to work, I looks to be written for an older SQL version 2005 or older.
SQL AGENT JOB.apm-template (6.8 K)
# I looking to just monitor the SQL Agent Job Status - I called support and I was told I had to use AppInsight for SQL as my only option . Its a resource drain on the server, is over kill and un-necessary.
Has anyone overcome this issue - I am not an SQL DB person - But will try anything.
Mike Lucci
