I am trying to download a config and it's failing. I think the problem is related to Solarwind's TFTP Server app. I have 2 nics on the server one using 100mbps and the other one using 1gbps.
In the NCM settings i selected the "Do not retreive IP automatically" and entered the ip fo the 100Mbps connection. I had to do that because when i clicked retreive IP, it would give me the IP of the other nic (1gpbs).
So now when I look at the TFTP Server app, I see bottom right that the IP that it is using is the ip from the 1Gbps NIC. I looked into the "Configure" menu of this app and could'nt find anything to change the IP that I would use for the TFTP Server.
Any way to change this?
