I recent taken management over SW and noticed we get a lot of false positives temperature alerts. I found how to change the sensor thresholds under hardware sensors but don't want to do that for each switch. Instead I was going to create a new alert and change/raise the values to stop this from happening. Can the alerts be set to an actually number? For example, 90 degrees F. When I select the field or look at the old preset alert, it has warning and critical in the value field but I can't seem to find what those actual values are. Any help would be much appreciated. Thank you!
