I currently have the eval copy of NPM 9.5 sp2. I accidently removed the Network Map from the the customize page section for the Home View.
How do you add this back?
Go to Admin -> Manage Views -> select Network Summary Home select edit and then add to which column you want to put it back into and choose Network Map
That did the trick.
Thanks for the help.
