Either i monitor SQL clusters virtual IP or add them individually in SAM.
But i am able to telnet to the port 1433 from virtual ip but i am unable to telnet 1433 from physical ip.
Please advise regarding this issue.
To monitor SQL clusters using AppInsight for SQL you will need to add the cluster VIP as a node in Orion. When the resources are listed for the Cluster VIP (volumes, interfaces, etc.) select the SQL instances you'd like monitored. More information can be found in at the link below.
