I trust all is well my SolarWinds THWACK Companions...
Are you able to help me with understanding and knowing what SQL Syntax I need to use to ideally get the results for Lines 11, 13 and or 14?
01 SELECT n.Location AS 'Site Location',
02 n.Caption AS 'Node Name',
03 n.IP_Address AS 'IP Address',
04 n.Vendor AS 'Vendor',
05 n.MachineType AS 'Machine Type',
06 nep.Model AS 'Node Model Type',
07 n.IOSImage AS 'IOS Image',
08 n.IOSVersion AS 'IOS Version',
09 ncc.chassisID AS 'Node Chassis ID',
10 ncc.chassisserialnumber AS 'Node Chassis Serial No.',
11 n.SystemUpTime AS 'Node Up Time',
12 n.LastBoot AS'Node Last Boot Up',
13 n.Status AS 'Node Status',
14 n.StatusLED AS 'Node Status LED',
15 n.Contact AS 'Support Team',
16 n.EngineID AS 'SWO Poller'
17 n.NodeID AS 'SWO Node ID'
18
19 FROM Nodes n
20
21 INNER JOIN NCM_NodeProperties ncm ON n.NodeID=ncm.CoreNodeID
22 INNER JOIN NCM_Cisco_Chassis ncc ON ncm.NodeID=ncc.NodeID
23 INNER JOIN NCM_Entity_Physical nep ON nep.NodeID=ncc.NodeID
24
25 ORDER BY
26 [Location], [Caption] ASC
Line 11;
How to display this as (YY:DD:)HH:MM:SS?
What SQL Syntax needs to added?
Line 13 and or 14;
What SQL Syntax can be used to show the Node Status Up, Down or Unmanaged replacing the 1, 2, 9
Or Line 14; Removing the *.gif?
Only 1 of these lines will be needed or wanted.
In the meantime I am now reading through the SAMs SQL in 24 Hours…
I will look forward to your feedback and recommendation to alternate SQL Syntax Code if necessary.
In addition, any recommendations on SQL Books or Commands Reference to help with the not so simple SolarWinds 'Out the Box' Reports.
Kind Regards,
DC4Networks
Confucius Says;
“The man who moves a mountain begins by carrying away small stones”.
