Is there anyone making use of scripts (VBSCRIPT) which can be output from a product named HP QUALITY CENTER along with APM monitoring or interfacing into APM Templates?
I'm not very familiar with HP's Quality Center but what is it that you're trying to monitor on it? Are you looking for an application template to monitor HP's Quality Center to ensure it's running properly or are you trying to visualize information collected by HP's Quality Center through the APM web interface?
The later..."trying to visualize information collected by HP's QUALITY CENTER".
All I know is, it can output VBScripts as it does QA testing. So, I was hoping to make use of that script placed within APM some how to perform a type of app health check.
Thanks for the reply.
